Home/ Questions/Q 21625
nano88
nano88
Asked: March 19, 20252025-03-19T00:51:43+00:00 2025-03-19T00:51:43+00:00In: Academy
error al ahcer click en objeto
Hola a todos, favor su ayuda con la siguiente duda. Cree un robot para que ingrese a una pagina y haga click en un objeto, pero no me esta haciendo el click, incluso le agregue un esperar a que el objeto este visible y no hay caso. tambien hice click en las cookies por si era eso pero tampoco resulto. Este es el error que me arroja:
2025-03-18 21:30:43.259844 – rpaweb – ERROR – EXCEPTION IN (<string> rpaweb, L_1116 «»): ElementClickInterceptedException: Message: element click intercepted: Element <a class="»elementor-button" elementor-button-link elementor-size-sm» href="/en/»https://market.rocketbot.co/es»/" target="»_blank»" data-gtm-vis-has-fired198462280_15="»1″">…</a> is not clickable at point (759, 20). Other element would receive the click: <a href="/en/»/#»">…</a>\\n (Session info: chrome=134.0.6998.89)\\nStacktrace:\\n GetHandleVerifier [0x00A9B5A3+24387]\\n (No symbol) [0x00A25904]\\n (No symbol) [0x00900753]\\n (No symbol) [0x0094EE50]\\n (No symbol) [0x0094D1F4]\\n (No symbol) [0x0094AD87]\\n (No symbol) [0x0094A044]\\n (No symbol) [0x0093E6D5]\\n (No symbol) [0x0096D84C]\\n (No symbol) [0x0093E164]\\n (No symbol) [0x0096DAC4]\\n (No symbol) [0x0098F138]\\n (No symbol) [0x0096D646]\\n (No symbol) [0x0093C59F]\\n (No symbol) [0x0093D8E4]\\n GetHandleVerifier [0x00D9D883+3179043]\\n GetHandleVerifier [0x00DB6CF9+3282585]\\n GetHandleVerifier [0x00DB167C+3260444]\\n GetHandleVerifier [0x00B34330+650448]\\n (No symbol) [0x00A2ED0D]\\n (No symbol) [0x00A2BAF8]\\n (No symbol) [0x00A2BC99]\\n (No symbol) [0x00A1E530]\\n BaseThreadInitThunk [0x75A85D49+25]\\n RtlInitializeExceptionChain [0x7762CE3B+107]\\n RtlGetAppContainerNamedObjectPath [0x7762CDC1+561]\\n
clickclickobjeto
  • 790 Views
    1. JoseL
      JoseL
      2025-03-19T15:25:16+00:00Added an answer on March 19, 2025 at 3:25 pm
      En mi experiencia, te diría que lo mejor que podes hacer es enviar el click con javascript, así no vas a tener ningún problema de que otro elemento recibe el click y eso.
      Ocupa un document.getElementById o ClassName y envias el click. Es mucho mas seguro.
    2. Bumblebee
      Bumblebee
      2025-03-19T13:36:40+00:00Added an answer on March 19, 2025 at 1:36 pm
      Hola nano88, buenos días.
      El error indica que el click fue interceptado por otro elemento y por eso no pudo realizar el click correctamente.
      Es probable que el elemento esté fuera del foco, puede validar esto colocando un comando de screenshot previo a ese comando.
      Pruebe colocar el comando Mover a Elemento previo al click, o si tiene la versión de Rocketbot 2024+ utilice el checkbox ‘Mover hacia elemento’ en el comando ‘Click en objeto’ del modulo nativo Web.
      Quedamos atentos a los resultados.
      Saludos!
    3. nano88
      nano88
      2025-03-25T00:21:13+00:00Added an answer on March 25, 2025 at 12:21 am
      Muchas gracias, al final lo logre con JS
    4. nano88
      nano88
      2025-03-25T00:21:45+00:00Added an answer on March 25, 2025 at 12:21 am
      Error al iniciar Rocketbot
      Error al conectar a BD oracle
      • Answers: 3
      Without access to Academy Rocketbot and its courses
      • Answers: 3
      Bot final Level 2
      Abrir Excel
