Home/ Preguntas/Q 24520
PaleyShelie
PaleyShelie
Asked: septiembre 19, 20252025-09-19T02:40:33+00:00 2025-09-19T02:40:33+00:00
MMOEXP-New World Season 9: Hammer of Yeet Hatchet PvP Build Guide
Although we’re already deep into Season 9 of New World: Aeternum, there’s still plenty of room to refine and experiment with builds before Season 10 rolls around. Investing time now not only strengthens your character in the current season, but also saves you resources, time, New World Coins and effort in the future. One of the standout builds that has gained momentum in PvP is the Hammer of Yeet Hatchet build—a versatile, high-impact setup that thrives on disruption, burst damage, and battlefield control.
This guide will walk you through the role of this build in PvP, the artifacts you’ll need to prioritize, and the steps to craft and optimize it effectively during Season 9.
Why the Hammer of Yeet Hatchet Build?
Season 9 introduced a new tier of artifacts that dramatically reshape how traditional weapon pairings function. The Hammer of Yeet Hatchet build thrives in PvP because it blends raw crowd control (CC) with consistent pressure and burst potential.
Hammer of Yeet: A war hammer artifact that amplifies knockback and CC effects, making it a nightmare for enemies trying to hold objectives or stay grouped. Its sheer control value allows you to dictate the pace of fights.
Hatchet: The perfect pairing to capitalize on enemies left vulnerable by the hammer’s disruption. With its Berserk healing and relentless DPS, the Hatchet ensures you’re never just a CC bot—you’re a deadly finisher.
The synergy lies in using the hammer to break formations, force cooldowns, and isolate targets, then swapping to the Hatchet to shred down opponents who can’t recover fast enough.
Core Role in PvP
The Hammer of Yeet Hatchet build functions as a bruiser–initiator hybrid in most PvP settings:
In 1v1 duels: You lean heavily on your hammer to create windows of vulnerability, then swap to the Hatchet for sustained DPS.
In group PvP (wars, arenas, OPR): Your primary role is disruption—using the hammer to knock enemies off capture points, interrupt healers, and peel for your allies. Once the chaos is unleashed, your Hatchet secures kills on retreating or staggered foes.
This balance of utility, survivability, and finishing power makes the build especially dangerous in the current Season 9 meta.
Key Abilities
Hammer of Yeet (War Hammer)
Shockwave: An AoE stun that controls groups and punishes clumped enemies.
Path of Destiny: A ranged shockwave that knocks foes off balance, synergizing with Hammer of Yeet’s enhanced knockback.
Clear Out: A wide swing that launches enemies back, ideal for objective disruption.
Hatchet
Berserk: Provides self-healing, damage boosts, and stamina regen—making you hard to kill in duels.
Raging Torrent: High-speed burst damage that deletes weakened opponents.
Feral Rush: A mobility gap-closer that ensures no one escapes once you’ve committed.
This ability combination ensures you can initiate, lock down, pressure, and finish fights without needing to over-rely on teammates.
Artifact & Gear Priorities
The foundation of this build is the Hammer of Yeet artifact, but rounding out your gear is just as important.
Hammer of Yeet
Special Trait: Increases knockback effects and enhances crowd control duration.
Role: Battlefield disruptor and CC enabler.
Hatchet
Recommended Perks: Refreshing Torrent, Keen Berserk, or Enchanted.
Artifact Alternative: If you can secure the Unstoppable Hatchet artifact, it further enhances your Berserk uptime, making you nearly unkillable in small-scale skirmishes.
Armor & Perks
Resilient: Reduces crit damage taken, crucial for surviving burst-heavy PvP opponents.
Refreshing: Shortens cooldowns, letting you rotate abilities faster.
Freedom: Reduces CC duration on you, ensuring you aren’t locked down when diving into groups.
Balance heavy armor for survivability with enough mobility to stay relevant in team fights. Many players run medium weight to maximize both mitigation and dodge rolls.
Crafting the Build in Season 9
To craft the Hammer of Yeet Hatchet build during Season 9, you’ll need a blend of artifact progression, crafting skills, and resource farming.
1. Securing the Hammer of Yeet
Drops from endgame PvP caches and specific high-tier expedition bosses.
Farm PvP track rewards consistently—this is the most reliable path to locking down artifact gear.
Alternatively, grind elite zones where artifact drops are common.
2. Crafting the Hatchet
Invest in Weaponsmithing for control over perks.
Use Timeless Shards to target Hatchet perk rolls like Refreshing Torrent.
Prioritize crafting Hatchets at Gypsum Kilns for guaranteed higher GS progression.
3. Armor Optimization
Farm Season 9 activities for artifact armor pieces, but also leverage crafting stations to roll optimal perk combinations.
Combine dungeon runs, faction missions, and PvP caches to accumulate crafting mats like Asmodeum, Runic Leather, and Phoenixweave.
4. Consumables
Infused Health Potions and Regeneration Potions are essential for sustain.
Oakflesh Balm: Reduces incoming damage when diving into groups.
Hearty Meals: Passive regen between fights.
Playstyle & Strategy
Open World PvP
Engage first with the hammer, aiming to scatter enemies.
Force healers or ranged players into panic with knockbacks.
Swap to Hatchet once a priority target is isolated—finish them before they can reset.
Arenas
Time your hammer stuns to interrupt burst windows from enemy DPS.
Use Berserk wisely—it’s both a survival and damage tool.
Coordinate with allies to chain CC, locking down key threats.
Wars/OPR
Specialize in point control. Your hammer excels at clearing enemies off objectives.
Rotate between peeling for healers and initiating engages.
Don’t overcommit—your Hatchet is best used after enemies are destabilized, not as the opener.
Final Thoughts
The Hammer of Yeet Hatchet PvP build is one of Season 9’s most disruptive and rewarding setups in New World: Aeternum. By blending relentless CC with sustained Hatchet pressure, you become a cornerstone in any PvP scenario—able to initiate, peel, and execute with equal effectiveness.
Season 9’s artifacts, especially the Hammer of Yeet, elevate traditional bruiser gameplay into something far more dynamic. Whether you’re climbing the PvP track, fighting in wars, or dueling in arenas, this build offers both impact and adaptability.
Invest the time now to New World Gold craft and refine it, and you’ll enter Season 10 with a fully optimized bruiser ready to dominate the battlefield.
  • 0 0 Respuestas
  • 17 Vistas
