Home/ Questions/Q 7383
joacobracci
joacobracci
Asked: Mayo 6, 20222022-05-06T13:09:02+00:00 2022-05-06T13:09:02+00:00In: Academy
Combine Paths with Strings
Hi, if i wanted to combine 2 strings to form a path, how i can do it? , because if i want to add {” C:\\\\\\\\\\\\\\\\x\\\\\\\\\\\\\\\\x\\\\\\\\\\\\\\\\x” } + { thing} + “.txt” it will get unicode error , so how i can do it? ,  Thanks!
path
    1. AucaCoyan
      AucaCoyan
      2022-05-06T13:23:42+00:00Added an answer on Mayo 6, 2022 at 1:23 pm
      Hello Joaco!
      I belive you have to escape the characters with `\`. Because of the symbol “/” that it has a special meaning in a few different languages, to send it as a string to a code you have to write “\/” wherever you need to insert “/” caracter.
      Another example is if you use “{“, you can’t send it directly as a string, you have to put \ in front of it. Like this “\{”
      Hope it helps!
      No me ha llegado la licencia
