Home/ Questions/Q 3571
nikhil.agnesh1@gmail.com
Asked: Julio 8, 20212021-07-08T15:39:39+00:00 2021-07-08T15:39:39+00:00In: Ejecución
Send data to nested Bots in Rocketbot
Hello,
Does anyone knows how to send data to child robot while calling it inside a robot with Execute robot from DB method?
My scenario is I have data in main robot and I want to use this data for executing flow of another robot from DB (Challenge is this another robot is called inside main robot).
Thank you!
question
      2021-07-08T16:00:52+00:00Added an answer on Julio 8, 2021 at 4:00 pm
      Hi nik,
      Just use the parent variable in the child bot.
      In the command you want to use it, you only have to call it between braces, for example: {var}
      *You must not create the variable in the child bot, otherwise, it will use its own and not the parent’s one.
      • nikhil.agnesh1@gmail.com
        2021-07-08T16:28:28+00:00Replied to answer on Julio 8, 2021 at 4:28 pm
        Hello Bender,
        Brilliant :),  Appreciate it.
        Thank you,
        Nik
